Emulator r40 Released
svenvandevelde
Post by svenvandevelde »
Congratulations with the R40 release!
Happy to see that the errors with the files and the mouse i had to report earlier have been resolved.
I will flag these as resolved and close the open ticket on github.
Have a look below, this is running on the CX16 R40 emulator (wip):
Note that there seems to be an issue with the -prg parameter of the emulator, but i need to investigate it further.
When I open up the emulator using the -prg option, i get this:
It returned:
zsh: bad CPU type in executable: ./x16emu
Never seen that error, and don't really know what it means.
Bad CPU type => Build target something else than the Intel Core i5 processor I have. Yes I know it's old ?
On 4/29/2022 at 7:05 PM, kelli217 said:
The RTC is working but the TI$ and DA$ hooks into the RTC are still a work in progress, eh?
Nope, TI$ and DA$ work fine already.  Launch the emulator with -rtc option.
Jestin
Post by Jestin »
On 4/29/2022 at 10:38 AM, Michael Steil said:
In the emulator, loading from SD card is very close to the speed on actual hardware. Loading from the host fs is faster, but since r40 at least not instantaneous.
Oh yeah, I can really see the difference.  One of these is running from the filesystem, the other from an SD card image.  Definitely going to have to pre-load some loading screens into banked ram.
Michael Steil
Post by Michael Steil »
Sorry, I built for ARM instead of Intel! ?
Try this one: http://pagetable.com/docs/tmp/x16emu_mac_TEST_CATALINA-2.zip
That version runs on my Mac.
Great work with the Kernal, by the way!
This begs the question... does there need to be a separate binary for Intel and Arm Macs? Or can your compiler produce a universal binary? (That was definitely a thing when Apple was transitioning from PPC to Intel.)
Trax81
Post by Trax81 »
Well, I guess I should have read the docs more thoroughly. ?
Michael Steil
This would happen if the file you are passing as an argument does not have a PRG header but starts with $00 $00. Otherwise, please file an issue.
