On 1/16/2022 at 9:01 AM, BruceMcF said:
Since he organized the instruction set for ease of hand-assembly, with only CPR having the opcode it has for functional reasons, I do think that saving odd/even in a zero page byte, and cutting the size of the two vector tables in half is the most useful decode.
However, after drafting several approaches, the game is not worth the candle ... the smallest I can come up with, without going in and copy and pasting from Woz's code, gets down to 416 bytes from the 496 bytes of the smaller version of the "pure" JUMP (optable,X) version that jumps directly to each OP. With a drop down to 394 bytes available from just adopting Woz's code, (including save/restore register code that Woz's version gets from the Apple II ROM), it's not worth it.
Not, that is, unless someone could find space savings IN Woz's version by doing some decoding, but as spaghetti coded as the original Sweet16 is, that someone would not be me.
If either version of my Sweet16 and Woz's original are assembled to be at the END of GoldenRAM, they each would have a different start point.
However, after translating a copy of Woz's code to acme assembler, with "SAVE" and "RESTORE" in front, I find there are six bytes at the end free before the end of the page. Then I could assemble versions of all three with a two routine jump table at the TOP of golden RAM ($07FA and $CFFA for CX16 and C64 respectively), one for entering Sweet16, the other for entering either SAVE or RESTORE (based on carry set or carry clear). Then the starting point of the routine is flexible, C64 code could enter Sweet16 with JSR $CFFE and CX16 code with JSR $07FE.
That would make it possible to assemble Sweet16 code independent of the choice of Sweet16 VM.
To fit into that, I'm going to shrink the size of my "two page" version by using INC Register and DEC Register subroutines, which will free up as much space as it frees up, and leave my "3 page" version as the full fat speed optimized version.
Edit: What I get is that the "full fat" Sweet16c would occupy $0500-$07FF of Golden Ram, leaving one page (256 bytes) free at $0400. The "two page" Sweet16c2 would occupy $061C-$07FF, leaving 530 bytes (two pages plus 18 bytes) of Golden RAM available at $0400. And the adapted "Sweet 16 original" with SAVE/RESTORE code included and the jump table would occupy $066f-$07FF, leaving 623 bytes (two pages plus 111bytes) of Golden RAM free.
TBC, none of those are tested code, so the final numbers may vary following bug fixes, but those should be the right ball park.
