PI Zero IEC Device
PI Zero IEC Device
I've thought about this very generally, and figured that to a large degree, data can be buffered in RAM on the storage device until transmission is done.  Since the X16's RAM footprint is small, a Pi buffer might remove any potential flash lag.
A multi-tasking multi-user operating system such as Linux is not suitable for this task.
^ Given.
So I wrote a simple one-wire noiseless no-ack ("SOWNONO") protocol between two Pi Zeros, in C, using WiringPi, on Raspbian.  It looks like I can get a whopping 500 bits per second.
In theory, then, plain old C with wiringPi and no ACK can get me 62 bytes per second.  No optimizations, no special nothing, and of course once they go out of sync it's disaster.
But it was fun to write and is a start.
I think if I revisit my simple talker, I'll define a frame and add an ACK.  I've seen a Michael Steil video where communication can slowly drift out of sync over dozens of bits...
But I'm also thinking about using my Arduinos -- I've got a Nano and a Mega 2560.
PI Zero IEC Device
That's why single-wire-per-direction protocols like RS-232 have a start and stop bit. The longer duration acts as a sync marker to keep the two UARTS lined up.
I'm still inclined to do something SPI over the User port. The Pi does hardware SPI just fine, and the only limiting factor there should be how fast we can bit-bang the port on the Commander side. (Which should be pretty fast if we have a bit shifter available.)
PI Zero IEC Device
Ok, that sounds useful.  I've done I2C but not SPI, so I'll start reading.
There's also the UART (pins 8 and 10 / GPIO 14 and 15).
PI Zero IEC Device
If we have access to the serial shift register lines, it can be used as MISO. If PB0 is used as the master SCLK, connected through to the serial shift register clock line so it can clock the input in, PB1 as MOSI, and PB2 to however high you want to allocate as SPI_SELECT, you can:
SPI_LSB:
   LDX #7
   LDA UPORT_PB
   ORA #%00000001
   AND #%11111101
   TAY
-   TYA
   LSR DATA
   BCC +
   ORA #%00000010
+  STA UPORT_PB
   DEC UPORT_PB
   INC UPORT_PB
   DEX
   BPL -
... with the MISO byte available in the Serial Shift Register data register when the process is finished, and with an accelerated loop when MOSI is "don't care", which can therefore be #0:
   LDX #7
   LDA PORTB
   ORA #%00000001
   AND #%11111101
-  STA UPORT_PB
   DEC UPORT_PB
   INC UPORT_PB
   DEX
   BPL -
