Emulator r39 Released
hey that's looking good!!
I wonder what the issue is with the mouse, in x16emu....
svenvandevelde
Post by svenvandevelde »
Me too. I've been looking into the code of the emu16 but it requires an explanation and a bit of a study before diving into it. It's not something you quickly can fix I guess without understanding the design and flow.
Jeroen
Post by Jeroen »
In r38 this code works just fine, just like it does in assembly, nothing fancy:
10 POKE $9F25,0
20 POKE $9F20,0:POKE $9F21,0:POKE $9F22,$20
30 FOR N=1 TO 80:POKE $9F23,N:NEXT N
In r39 however, this doesn't output anything. I'm using both the Linux and Windows versions, same issue. Am I missing something here?
JimmyDansbo
Post by JimmyDansbo »
Default text screen memory has moved to $1B0000
https://github.com/commanderx16/x16-docs/blob/master/Commander X16 Programmer's Reference Guide.md#video-programming
Visit my Github repo
Jeroen
Post by Jeroen »
On 4/2/2022 at 8:50 PM, JimmyDansbo said:
Thnx. So using text mode with VERA, one needs to also account for the $B0 offset for every vertical line ?
Yeah I had to change several routines in prog8's textio library to to add $b0.  But application code doesn't have to deal with this, and started working again after I changed the library.
Another way to deal with this is to use VTUI library which has just been updated as well for the new r39.
Michael Steil
Post by Michael Steil »
You could read the start of screen RAM from the VERA registers and be compatible with any start address! ?
svenvandevelde
Could BSOUT/CHROUT writing to screen have the same approach in the ROM and have somewhere a register that indicates to which layer it writes?
Would a pull request be an option to consider?
Rather than overloading output routines, it might be better to have a new Vera settings retrieval call.
JimmyDansbo
I am sorry, I may have missed something, but as far as I know it is hardcoded that kernal routines use layer 1. What would be the benefit of having it say so in a register or memory location?
If you want kernal routines to work with something different than defaults, you should modify layer 1 registers, call kernal routines, then reset layer1 registers if needed.
