New demo uploaded: Pirate Kingdoms
On 1/26/2022 at 9:36 AM, SlithyMatt said:
Mainly, you need to make sure you are doing the scrolling during VBLANK by putting it at the beginning of your VSYNC interrupt routine. That should clean it up a lot.
It doesn't work.  By that I mean it DOES work, but C is so slow it reduces the game to a crawl.
The function I tried using is called waitvsync(), strangely enough.  Standard with cc65's <cbm.h>.
On 1/28/2022 at 10:10 PM, ZeroByte said:
I forget exactly every step I did in Flappy Bird, but it does IRQ handling in C.
Basically, I made a #define that makes the IRQ vector in RAM ($030-something)  so it looks like a variable, and then I did an inline assembly to SEI, then IRQ_VECTOR = &irq_handler;
Something akin to that.
THAT might work.  Better than waitvsync() anyhow.
I'm impatient now though, and I want to get on with writing some playable content to the game.
Got any images to show?
