SweetCX16
Scott Robison
SweetCX16
Post by Scott Robison »
On 1/13/2022 at 10:34 PM, codewar65 said:
If the 6809 sold at the same price or less than a 6502, would Sweet16 even exist?
Probably, since Apple 2 predated 6809.
codewar65
SweetCX16
Post by codewar65 »
Apple's garage computer was a piece of wizardry. Woz made an amazing machine with what he had. Jobs made the world eat it.
I was picked out to help my high school select a system for our first computer lab back in the early 80's (I was one of a few kids in school who already owned a Home Computer). Tandy vs Apple vs Commodore. I picked the Pet as it was a serious machine (i've seen all three in action and specs); the school (as did many) ate the Apple. Because of educational discounts to indoctrinate the youth to continue to eat the Apple. We still see the effects to this day.
Apple = Eye candy. Get a real system.
The 6809 was a wonderful processor that I have worked with. With the (indirectly with the SuperPet SP9000) and with coding the chip directly. I wish it took off. Really.
SweetCX16
My computer knowledge really took off in grade 12 when the typing teacher removed me from the regular class (I think my knowledge and ability really challenged her.) I was given a SuperPet, disk drive and the complete set of Waterloo languages with manuals  to work in another room (so I wouldn't be disruptive to the main class or teacher.)  Structured Basic, Pascal and Fortran were real joys, APL was just neat but my background math knowledge was lacking. Assembler on the 6809 and 6502 interested me; I should have done more. Cobol didn't make sense then (or now) - that experience suggested I avoid working it for Y2K.
From reading about the evolution of the Waterloo languages, there must have been a couple of engineering/CS students who had exposure at the university level. Hopefully they benefited from the experience.  I did!
codewar65
SweetCX16
Post by codewar65 »
Waterloo on the SuperPET. *warm fuzzies* BASIC, Pascal, and FORTRAN. They never offered APL at my college. I did take up COBOL at university and ended up do stupid Y2K stuff at a job decades later...
SweetCX16
In Ontario (a large, rich province in Canada), a couple of PETS were in the math classrooms in the early 80 when I was in grade 7. In New Brunswick (a smaller economically challenges province), I got to use PETS from 1984-1987.  The main lab had several pets chained to one disk drive - most likely the cheapest option. There were a couple of single machines, the versions I don't remember save the SuperPet that help make me a "super" programmer. ?
My understanding is that Comodore pushed heavily into the school systems in Canada.
SweetCX16
This is getting off topic, better suited for another place on the forum, but yeah, fuzziness.
Scott Robison
SweetCX16
I had to take APL in college. I remember virtually nothing of it, and it is truly write only code (at least in the environment we used).
SweetCX16
If it was sold at the same price or less than a 6502 at the time of 6502 introduction, possibly not ... the 6809 is a fine instruction set.
Regarding the original topic, I've been looking at something I mentioned in another thread:
However, even with a different dispatch model, if trying to squeeze object size in a "Sweet 16 replacement", rather than optimizing for speed, I could imagine have a single indirect load and a single indirect store routine, which works out from the bits of the opcode and the status of the carry flag whether it is pre-decrement or post-increment and whether it is a single or double byte operation, covering 7 operations in two routines. Direct register moves could be handled by putting source in Y and destination in X, at the cost of using absolute rather than direct addressing for the Y-indexed operation, giving one routine the two direct ones. One could imagine the immediate register load being run by the two-byte accumulator load, setting the indirect source register to R15, the PC register, and using Y-indexed store, so the immediate load is taken over by the single indirect load routine as well.
Then at the cost of three more zero page bytes ... two more bytes in a dedicated "register 17" initialized to $0001, and one set to either $80 or $00 based on whether adding or subtracting, setting up the correct target and operand index in X and Y would all allow all five arithmetic operations to be done in a single routine. If that was done by shifting the instruction one bit to the left and using the carry flag and sign flag to split the code set into quarters, you might restrict the jump table to the $0n instructions, making it only 26-32 bytes long
After looking more closely, the same routine can handle byte and word indirect load, the same can handle byte and word indirect store, and with an entry stub byte pop and byte store-pop (before SIGN is examined to see whether to run load or store). So that's six operations with two routines.
The same routine can handle add and subtract, and with an entry stub compare. A single routine can handle direct load or store, a single routine can handle increment and decrement. So that's seven more operations with three routines.
Among the "embedded register" operations, only word pop (POPD) and SET are singletons, because the way that the first decrements twice in process, which cannot be handled by a prefix to indirect load or store (which post-increment), and setting a value with the contents of the accumulator doesn't make any sense.
Even though each routine is longer than the SweetCX16 routines, the reduction in number of routines to seven to cover 15 operations  makes the codesize smaller.
In the dispatch, after branching to handle the "Branch & etc." ($0n) ops by using the bit4 value to set SIGN to $00 or $FF, clearing bit4 and LSR four times to get one of eight index values from 0 to 14, storing that in X so that JMP (REGOPS,X) based on a 16byte (rather than 30 byte) vector table, saving 14 more bytes.
Handily, the index (even numbers from 0 to 14) are in both A and X on dispatch, so if the index is used (as in indirect loads and indirect store to tell whether it's a byte or a word load), you can do "TYX: TAY" to save the index where it can be tested directly with "CPY #n".
I haven't tackled the Branch operations, but I am thinking a similar process can be used with the low bit of the operand, since 8 of 13 are by pairs: Branch No Carry / Branch Carry; Branch Plus / Branch Minus; Branch Zero / Branch Nonzero; and Branch if Minus 1 / Branch if not Minus One. If Carry, Minus, Nonzero, and non-Minus 1 are each tested with a result of #$0 if the condition is met and #$FF if the condition is not met, then jumping to BRANCH with EOR SIGN will invert the status for the "odd" operands (Carry, Minus, Nonzero, Not-minus one), and leave the status alone for the "even" operands. Then a branch is performed if the result after EOR SIGN is $#FF. Then Branch Always simply calls BRANCH with a status of $00, since Branch Always is an "odd" op. So that handles 9 of 13 ops. RTN is easy, since it is op $00, "CMP #0 : BEQ RTN". BRK, RS and BS are all singletons, but the dispatch can use the "SIGN" value to distinguish between BK and RS and jump to BS on it's own, so filter out RTN, extract SIGN based on the low bit, clear the low bit, transfer to X and do an X-indexed Jump on a 14 bytes index table ... rather than 26 in SweetCX16 ... crunches the size even more.
The hope would be to get smaller than the original Sweet16, so that there is a "faster, large footprint" version and a "slower, smaller footprint" version.
SweetCX16
Yep, I was messing with those opcodes, grouping them one way and another, thinking "surely a little decode can reduce size".  I'm sure Woz didn't decode because 300 bytes was the golden compromise for him.
SweetCX16
Since he organized the instruction set for ease of hand-assembly, with only CPR having the opcode it has for functional reasons, I do think that saving odd/even in a zero page byte, and cutting the size of the two vector tables in half is the most useful decode.
