My wedge-style retro computer case
Feel free to talk about any other retro stuff here including Commodore, Sinclair, Atari, Amstrad, Apple... the list goes on!
AndyMt
Post by AndyMt »
Hi everyone
while waiting for the X16 to get real, I started to design my own computer case. I want it to resemble the keyboard or wedge-shape cases of the 80ies era. I owned a TI-994A and a Atari ST back then and I wanted to have something similar where I can put the X16 board in. As I just started with 3D printing I fired up Blender and started designing. After many, many hours of sketching, klicking, dragging and swearing I started printing the whole thing. Then I integrated a xtrify ten-keyless keyboard (which I want to lower a bit) and integrated a MISTER, Raspberry Pi (and a KVM Switch). This now gives me the full retro vibe - until the X16 will arrive...
So this is how it looks now, what do you think?
right.thumb.jpeg.ff26dfb1968124f1e2f7c705fab060ba.jpeg front.thumb.jpeg.713e9a225204a1afbe1ffce3f0c2ed30.jpeg frontleft.thumb.jpeg.a4b79a7d8eb444577deeca6243109065.jpeg
EDIT: updated pictures with most current version.
This is the finished case. Now I have to stuff all the hardware in...
What's not to like?
Are you considering it a one-off, making plans available, or even going for a commercial run?
Not bad! I've been looking at another all-in-one keyboard, but this one is better looking.
Will you be making the design available in some form, once it's finalized? I have a friend who's willing to print a case on his large bed printer... this would be perfect for that use.
AndyMt
Post by AndyMt »
Never say never... but I have no experience with non-software commercial projects at all. Production, stock, logistics... let me put it this way: unless I find a partner taking care of this, this will be a one-off from my side.
I for sure will put the design on Thingiverse - at least for non-commercial use.
The parts are split so they fit on a 230x230mm print bed and with that the side pods have to be printed 45° diagonally. Without splits the largest piece would be 380x225mm (base plate). The overall size of the case is 395x240x65mm. You need to find a suitable ten-keyless keyboard to integrate. The stands I've modelled fit the Xtrify K4 keyboard which is available in a retro colour scheme.
As this is my first big structure I've modeled and 3d printed probably there are better ways to split parts etc. I already know some awkward corners I want to fix first before publishing it.
Thanks for the response. I appreciate that you realize that experience is a limitation to making this a commercial product. Making it available to those who want to build their own is noble; I think many will thank you for that.
Partnerships can be work in itself; it sounds like you have thought about that too.
I do hope you get it to publication. Not that I have any ability to manufacture one myself. With the project based case "unplanned" at least the earlier design goal of using a standard enclosure seems like a very wise decision.
I find your case good-looking and impressive. I hope that once the X16 ships I'd be able to find a case as attractive as the one you've designed and built.
Tatwi
Post by Tatwi »
Somewhere I read someone's feedback on essentially the same concept applied to a different computer and I have to say, I totally agree with their assessment, which was something like...
Wedge computers of the era didn't really have keyboards all the way to the edge of the chassis.
While that isn't entirely accurate, I agree with the sentiment, because I think there is a certain visual balance between "this is a computer" and "this is a keyboard"... yeah, something like that.
I would say that if you're going to do another version, maybe make it a bit wider. Depth wise, it already looks like a computer. Perhaps you could even offset the keyboard to the left or right and put something in the empty space, like the super sexy Atari 600 or your old pal the TI-994A.
I too have designed a few wedge machines in Blender over the years, but I never built any of them. Good on ya for actually building yours!
Ps. As a humble non-owner of a 3D printer, I am still afforded the luxury of thinking of ways to make things without printing them. This lead me to looking into buying some sheets ABS plastic for cutting, bending, and gluing. Bending anything long isn't really practical for a home user (deep bucket of specifically temp'd hot oil and a bending jig), but cutting is actually really easy with just a jig saw or a coping saw, and gluing is as easy as it sounds. Using a purchased sheet for the bottom and perhaps the side and back panels may be more ridged or smooth (or textured, depending on what kind of sheet you buy). Awesome that you have a printer though - Maximum Creativity! ?
AndyMt
Post by AndyMt »
I agree with this. It's probably not visible in it's current state, but the case is 2.5cm wider on each side than the keyboard and 2cm in the front. That's more than the Atari ST or the Commodore Amiga had. As for ofsetting... no, I'm too much of a fan of symmetry... The cursor key layout already adds enough visual asymmetry for my taste.
Thanks ?. I tried with Balsa-wood and Polyester resin last year, but gave up, it was too much of a mess... Having the printer makes things so much easier. And stuff really fits together as planned.
xanthrou
Post by xanthrou »
Awesome case! It really does retain the combination of 'new' and 'retro' like the keyboard-less design!
Strider
Post by Strider »
Simply put....
I love it! ?
Excellent job! Now I want one. lol
I want too many things.
A classic geek & family man who enjoys all things retro! Computers, hardware, games, electronics, etc. Expert at nothing, professional hobbyist, and old-school blogger!
Tatwi
Post by Tatwi »
I hear ya with the desire for symmetry, but having looked at loads of pictures of these types of computers over the last four or so years, I think the designers of asymetric machines were really on to something. I think my favorite designs was the Commodore Plus/4 until I discovered the Sanyo AX230R MSX computer in red - it just looks so cool, man!
Also, I wanted to apologize that I didn't acknowledge and congratulate your success and design enough. I really do think it's pretty awesome that you actually built it and the chassis itself really nice looking!
Stuff fitting together as planned... that would be amazing! Sadly my wife is pretty stuck on the whole, "we don't need a 3D printer" thing and while she's not wrong, she also hasn't really built anything, ever.
My sticking point with stuff like this is that I just keep asking myself, "Is this practical? Is this necessary?" and the answer is always, "no...", so I tend to leave it at that until it something sparks my imagination again. One such time was last May when I decided that I needed to know how practical it really would be to have a custom wedge computer on my desk. See, a few years ago I bought a cheep 10 keyless keyboard and some custom keycaps for it (roughly $40 CAD total) to use in a custom wedge chassis, but I never got around to building the chassis. I couldn't decided what I really wanted to do with it. Anyway, in May I went to the basement and made a big mess with Styrofoam and craft paint to create this haphazard monstrosity...
I plugged it into my PC and it only took an hour to determine the whole thing was kind of stupid and pointless really. As only a keyboard, it just didn't serve any practical purpose and its added depth made it a nuisance. And then paired with the modern 24" wide screen LCD, it didn't even "look cool", instead it looked out of place. So from this experiment I determined that...
The retro computer needs its own retro monitor and the system needs to be setup in its own retro space, otherwise it's just... weird. Context is everything!
And with that in mind, I was wondering what kind of physical setup you have for you Commander X16 station? And I suppose, how important is that space to you in general? Do you foresee yourself using the X16 regularly or will it be more of a display item? And do you have a space that can be a just a display area? I actually wonder about this with everyone, because ya know, context is everything! ?
Personally I have a U shaped desk that I cobbled together from an L shaped desk and various other bits of junk. I once had my Compaq Deskpro 4000 Pentium system setup at the secondary seating station to my right, but I found it made the space feel closed in and, honestly, the flat empty space was way more useful. That said, I picked up a small 4:3 LG LCD TV from a thrift store for $3 a while back and think it and a wedge computer would fit that space really well, without feeling crowded. However, the computer would have to be something I actually used regularly, because my nerd-space is limited to this 6'x6' square of the universe and I would be giving up doing other things with that desk area to accommodate it.
Back the olden days we didn't have these sorts of issues, because the wedge computer was the main/only computer in the house and thus it served such purpose as to warrant a space in our homes. Today, they're just toys, if we're being honest. And it's totally fine to have toys at any age, but you know, context, right? How we use these old machines in the modern world is an interesting subject of its own...
