1 hour ago, BruceMcF said:
Then you were undercounting, there are YM2151, DAC, VERA PCM & VERA PSG left.
I apologize for misunderstandings. Though is it possible to use VERA PCM and YM3012 simutaniously?
17 hours ago, AndyMt said:
Yes, you can use YM2151 and the VERA PSG+PCM at the same time.
On 9/12/2020 at 1:23 PM, Fnord42 said:
TBH I am still a bit disappointed about the X16's sound capabilities, mostly because I had hoped it would be able to play MOD files, which does not seem to be possible with the current hardware. (Despite having four(?) different chips with overlapping capabilities, which also feels a bit weird to me.)
I assume that it is much too late to change the general design of the X16's sound architecture (and, more importantly, that the core team probably had good reasons to go for the chips they chose, that I am not aware of).
But I have been thinking if it might be feasible to build a sound card for the X16 instead. I haven't investigated the topic thoroughly yet, but the fact that there are complete MOD players consisting of not much more than an ATMega32 and a TDA1543, makes it seem quite doable. To clarify, I don't want something that just plays a MOD that you throw at it, but rather the necessary hardware that would enable the X16 to play MOD files (for example as background music in a game) - you should be able to upload samples/instruments and then play them at different frequencies, much like the Amiga's Paula chip did, If I understood it correctly.
What do you guys think? Is this a good idea or a bad one, and why?
51 minutes ago, BitBlit said:
Hi,
I recently added a mod player
It's in a very early stage and there are many features missing but it shows that the CX16 is capable of playing mod files.
I'm still working on it...
3 hours ago, Johan Kårlin said:
I just found this thread when thinking about the exact question that started it almost a year ago. The FAQ still says that the YM2151 may not make it to the final product, but it is still there on he latest revision of the motherboard. I understand this as it is very unlikely that it will be removed. Or am I jumping to conclusions?
