LOAD"$",8 not working on sdcard
AuntiePixel
Post by AuntiePixel »
When I launch the emulator with an sdcard, the LOAD"$",8 command doesn't work anymore.  When I try it, I get "Searching for $" then "Loading from $0801", and it just sits there indefinitely. The same command returns a directory that I can LIST just fine when I don't mount an sdcard.
Oddly, the X16 Edit text editor, and the DIR.PRG directory listing apps can get listings from the sdcard. And I'm able to save/load from the sdcard if I already know the file name. With the DIR.PRG program, I can at least get a directory listing, so it's not critical. But I am very confused why the standard BASIC command isn't working.
Any info or advice that might help enlighten? And thanks again for helping a newbie
try DOS"$   instead
AuntiePixel
Thanks! that's super useful. Still curious why the basic load command doesn't work, but I won't be using it anymore anyway now I know this.
