New community dev tool uploaded: cc64 X16
pzembrod
Post by pzembrod »
cc64 X16
View File
cc64 is a small-C compiler, written in Forth, targeting the 6502 CPU.
It's hosted on the C64, on the C16 with 64k RAM, and now on the X16.
Runtime targets are available for all 3 platforms, on each host, allowing cross-compilation.
The code lives at https://github.com/pzembrod/cc64.
It's licensed under the 2-clause BSD license: https://github.com/pzembrod/cc64/blob/master/COPYING
See https://github.com/pzembrod/cc64/blob/master/Usage.md for usage.
See https://github.com/pzembrod/cc64/blob/master/C-lang-subset.md for details about the supported subset of C.
See https://github.com/pzembrod/cc64/blob/master/Lib-reference.md for the the LibC subset that comes with cc64, plus the lib's deviations from the standard.
This is wizardry.
I'm really looking forward to try this out! Very nice achievement.
kktos
Post by kktos »
I thought about asking why in forth.... then I saw your explanations ?
For fun.
That, I can understand :):)
Viel Spass.
Downloaded it now, and tried it out for the first time.
It's working! A real accomplishment.
I have skimmed the instructions you published. Do I understand correctly that there are no standard libraries? We may need to develop such libraries, for instance to call Kernal routines.
pzembrod
Post by pzembrod »
For fun.
Well, fun was and is the reason for doing cc64 in the first place. And Forth is and continues to be fun.
But the original reason for using Forth was that it was the best high level language I could find on the C64 back then - powerful, practical, and producing very compact code.
Viel Spass.
Danke, gleichfalls!
pzembrod
Post by pzembrod »
It's working!
Glad to hear!
Thank you!
Yes, that is correct ... yet.
Absolutely! The kernal-io-c64.c and kernal-io-c16.c files might serve as an example or a starting point. But going forward there should be at least a basic subset of the C standard library.
pzembrod
Post by pzembrod »
Update: I haven't created a new release yet, but I would encourage folks to give the current v0.9-dev version a try, as it features a significant compile speed increase:
https://github.com/pzembrod/cc64/blob/v0.9-dev/cc64-x16files.zip
https://github.com/pzembrod/cc64/blob/v0.9-dev/cc64-x16files-sdcard.zip
pzembrod
Post by pzembrod »
Update: v0.9 is out, as you may have noticed, and I have started work on a standard library, based on http://pdclib.rootdirectory.de/, in the v0.10-dev branch.
