9 hours ago, Fnord42 said:
That doesn't sound too bad - so the CPU could for example instruct an expansion card to write data directly to a specified memory area without having to squeeze everything through the 32 bytes of dedicated ram
It's not really RAM - it's I/O space. The system is set up so that when addresses within that 32 byte range are selected on the address bus, none of the internal memory chips respond. Instead, an expansion device is expected to set data on the data bus.
So if you were going to use DMA to pre-load the system, the CPU would have to set one of those 32 addresses to particular value. The expansion device would be looking for that value at that address, then it would assert the DMA pin, and the CPU would shut down. Then the expansion device owns the bus while it does its thing.
That thing can be: populating memory on the Commander, reading from the Commander memory, or even accessing the Commander's I/O devices (including VERA). So, as Bruce suggested, if you had an external processor on that bus, you could even take over the system completely and run it with something like a Z80 or 65816.
This is how the CMD super CPU worked, as well as the CP/M cartridge and the 1750 Ram Expansion Unit.
However... this requires a "smart" expansion cartridge, which doesn't make as much sense for simply distributing games or software. You'd be adding significantly to the cost to build a CPU onto the cart when all you really need is a PRG file that can be loaded from SD.
Missing autostart capabilities are probably not much of an issue, if that can be done via sd card. I hope it will be possible to run multiple autostart programs in a row, so I can load the drivers for my expansion cards and still autostart my boot menu system or favorite game or whatever
If I recall, The way Lorin described it was that the startup script would be a bit like a DOS batch file. It would contain a series of BASIC statements that would be executed from a buffer.
So a menu program would not actually BE the startup script. It would be called FROM the startup script, which might look something like this:
POKE 0,1:LOAD "SERIALDRIVER.PRG",8,1
POKE 2,2
POKE 0,1:SYS $C000
RUN
LOAD "MENU.PRG"
RUN
In this example, you'd be loading a resident routine into bank 1, setting a configuration variable (POKE 2,2) to tell the program which expansion port to use, and then starting the driver (SYS $C000).
After that, the startup script would load the menu program into BASIC memory and launch it normally.
