New productivity upload: Living Type - A Chinese Word Processor
Inkbox
Post by Inkbox »
View File
Living Type for the Commander X16
A Chinese Word Processor for the Commander X16 that supports 10,000 Chinese characters.
The program itself is called "HUOZI.PRG" and the resources should be kept in a folder called "huozi" on the SD card or file system.
Huozi is the romanization of 活字, the name given by Bisheng to his 11th century invention of moveable type.
IMPORTANT: The huozi folder and should be kept in the same folder where the Commander X16 emulator is located in order to run properly.
LOADING:
From the home screen of the Commander X16 load the program with
LOAD "HUOZI/HUOZI.PRG"
Followed by
RUN
Once the program is loaded press any key to get past the title screen.
CONTROLS:
To toggle Chinese input press: SHIFT + SPACE
To toggle Command Mode press: CTRL + C
There are 4 commands the program can preform:
1. save
save [filename]
Which saves a binary text file to the huozi folder and [filename] represents your given name to the file
2. load
load [filename]
Which loads a binary text file from the huozi folder and [filename] represents the given name of the file
3. new
new
Which creates a new document for the user (erasing all current data held in memory)
4. color
color [0-9]
Which sets the text color to one of the ten selected colors
Demo
In Command Mode try out
load data
To see a text file containing 4800 Chinese Characters
load david
To see some PETSCII art
It seems to work without any apparent bugs. I also tried to run it in the current master branch emulator with the -randram option, and that worked too.
Commands are specified in a command box at the bottom of the screen similar to Vi. Have you thought of actually naming commands in the same way as in Vi?
Now I only need to learn Chinese ?
Inkbox
Post by Inkbox »
I never thought about using Vi commands, and I'm not planning on any additional features for this program at the moment, so perhaps I'll keep that in mind incase of any future updates to it.
ZeroByte
Post by ZeroByte »
This is impressive
yosi2112
Re: New productivity upload: Living Type - A Chinese Word Processor
Post by yosi2112 »
I am looking for the source code for this word processing software, but github only has compiled binaries.
The purpose is to create a software modified for Japanese.
If possible, could you please release the source code?
