SPRITECALC (Sprite Calculator)
schristis
Post by schristis »
SPRITECALC.PRG
(11.68 KiB) Downloaded 18 times
Plug in the 'Sprite Attributes' and it will give you the BASIC program to display that sprite.
Use your mouse to click in the grid to change the attributes.
Should be self explanatory enough if your learning how to use sprite's.
or need a BASIC program to display your sprite.
I Started making this a few months ago, and works great to get the BASIC program.
Ohh remember.... you can put a 'dollar sign' $ in front of a value to make it hex.
I did want to add some example sprites to practice on, Just haven't had time to do it yet...
Admittedly I've had to be MIA for a while lol....
