Bouncing ball within a bouncing frame
MarkTheStrange
Post by MarkTheStrange »
This was a challenge on the Facebook C64/C128 programmers group:
Create a sprite with a frame. Bounce a pixel within the sprite's frame. Bounce the sprite on the screen.
I thought an X16 version would be a fun task. The challenge was specifically to do it entirely in BASIC on the C64 using an expanded sprite (double-width, double-height) in a program with the smallest memory footprint (my X16 version takes up 244 bytes, but you get to stare at a screen doing nothing for many seconds while it initializes the sprite bitmap dynamically).
Since a square sprite makes for a boring bounce along a line between opposite corners, I made the ball bounce within a 48x42 rectangle inside the 64x64 sprite (to match an expanded sprite on the C64).
Screenshot 2025-02-19 at 17.14.51.png (69.17 KiB) Viewed 746 times
METABOUNCE.PRG
(254 Bytes) Downloaded 38 times
Re: Bouncing ball within a bouncing frame
MarkTheStrange wrote: Wed Feb 19, 2025 10:22 pm This was a challenge on the Facebook C64/C128 programmers group:
Since a square sprite makes for a boring bounce along a line between opposite corners, I made the ball bounce within a 48x42 rectangle inside the 64x64 sprite (to match an expanded sprite on the C64). Screenshot 2025-02-19 at 17.14.51.png
Had to do my Own version :D . I DID NOT even look at Mark's code.
BOUNCE.PRG
(4.76 KiB) Downloaded 19 times
BOUNCE.BAS
(5.61 KiB) Downloaded 5 times
MarkTheStrange
ahenry3068 wrote: Fri Feb 21, 2025 2:53 pm Had to do my Own version :D .
Well, that's much fancier. Change the frame to a gilded picture frame and it will fit right in. :)
MarkTheStrange wrote: Fri Feb 21, 2025 3:39 pm
That's doable... I will see.
Looks like Robin saw the challenge too. [yt]https://www.youtube.com/watch?v=zwTA7xi0QD0[/yt]
Bouncing ball With some Physics
Added some interaction between the ball & the box.
BOUNCE.PRG
(4.8 KiB) Downloaded 14 times
BOUNCE.BAS
(5.72 KiB) Downloaded 3 times
There's some weird physics going on with the ball though. It changes course sometimes even when it is not actually touching the sides of the box.
