I feel like a total beginner. Well - I know how to program in many languages and I learned BASIC as my first language and when I owned a C64 (Why did I ever sell it?) I spent many long hours programming on it. Today I feel lost.
The thing about 8bit technology is that it is so tightly bound to the hardware. I don't have to tell you all that. You know it too.
I keep trying to do things and figure out things - I know I can do this, but the manuals are spread all over the place and a lot of knowledge is squirled away in the forum (and God help me if I can get a search that returns meaningful results - thanks google!) it is challenging to make much progress. Then I get something to work! A little victory. I feel elated. I am ready to try my next wide idea.
Right now I am just playing with BASIC. Man - some of you all are really good at this!
Today I am trying to figure out character sets. I know there is an X16 character set and a PET character set. It seems that right now I am using the Pet character set. Can I change it? Can I change it in code? Any insights would be great.
Thanks
Coming back to C64 programming after 35 years...
- JimmyDansbo
- Contact:
Re: Coming back to C64 programming after 35 years...
You can switch between ISO mode and PETSCII mode with:
https://github.com/X16Community/x16-doc ... d#iso-mode
Below table may also be of help:
https://cx16.dk/cx16-petscii/
CHR$($0F)and
CHR$($8F)When in PETSCII mode, you can switch between upper- and lowercase with:
CHR$($0E)and
CHR$($8E)You can find the documentation here:
Visit my Github repo
Also you can press SHIFT+ALT at same time to swap between the two PETSCII modes (this is immediate and won't clear the screen, it just toggles the loaded font set), and ALT+O to enter ISO mode (this will clear the screen, as a reminder that you're enabling a quite different font set, at least in the extended >127 region).
To experiment, try the following simple BASIC:
Then press SHIFT+ALT to see the difference in font-set.
The console/CMDR-DOS and keyboard use one mapping (PRINT uses that mapping), while the display character set uses yet another mapping (TILE uses that mapping). Often it is faster to work directly with screen codes (like if you want to draw a box in text-mode using PETSCII symbols). Other times you want to make use of PRINT, MID$, CHR$
1 SCREEN 1
5 REM REGULAR PETSCII CHARS (OR ISO IF IN ISO-MODE)
10 FOR I = 33 TO 126 : REM AVOID 0 TO 32, THOSE ARE CONTROL CODES
20 PRINT CHR$(I); : REM THE SEMICOLON IS IMPORTANT HERE
30 NEXT I
35 REM SCREEN CODES (OR DISPLAY CODES) VIA TILE KEYWORD
40 FOR I = 0 TO 60
50 TILE I,4,I
60 NEXT I
70 LOCATE 8,1
- charset_screencode_sample.jpg (135.93 KiB) Viewed 1530 times
