Damon: The Rocket Jockey
natebarney
File Download Damon: The Rocket Jockey
Post by natebarney »
Damon: The Rocket Jockey is a clone of Nomad: The Space Pirate, a C64 game I remember fondly from my youth. It's written in 65C02 assembly. The code is available at https://github.com/natebarney/damon-the-rocket-jockey
The goal of the game is to pick up all of the pellets on each level while shooting or avoiding the enemy ship(s). Once all pellets have been collected on a level, shoot any remaining enemies to advance to the next level. A bonus ship is awarded every 10,000 points.
The game accepts input from any of the controllers attached to the system, including the keyboard joystick. The D-pad or arrow keys steer your ship, and any other controller button fires your gun.
It's been tested on ROM version 47 in the emulator and ROM version 46 on real hardware.
#R47
UPDATE 2025-03-30: Version 1.2.0
  • Added PCM music track, a new composition expanding on the original music
  • M key cycles through PCM (new), FM (original), and off
UPDATE 2024-05-26: Version 1.1.0
  • Q key now quits from anywhere, not just title screen
  • M key toggles background music on/off
  • Tested with ROM version 47 on real hardware, with both 65C02 and 65C816 processors
damon-1.2.0.zip
(162.63 KiB) Downloaded 76 times
damon-1.1.0.zip
(7.05 KiB) Downloaded 392 times
damon-1.0.0.zip
(6.99 KiB) Downloaded 636 times
Re: Damon: The Rocket Jockey
I played it on the Web emulator. Couple items:
  • "Q" does not quit the game, except from the title screen.
  • An option to turn the uh...music off would be nice.
Otherwise, a fun little game.
natebarney
Thanks for the feedback!
My primary goal when writing this game was to match the original as closely as possible. Both points you mentioned were done intentionally to that end. However, they're good suggestions, and I'll look into incorporating them. Thanks for that.
Regarding the "Q" issue, would you find it more natural for it to return to the title screen or quit the game outright when pressed during gameplay? I'm leaning toward the former, but I'm curious what others think.
Regarding the background music, it is fairly close to the music in the original, and admittedly it's no Mozart lol. It seems to me to be a variation on the bass line from the Peter Gunn Theme. But it is repetitive, so I can see why some might want to turn it off. Interestingly, as a friend pointed out to me the other day, the "level complete" jingle seems to be a minor version of the opening to Pictures at an Exhibition: Promenade by Mussorgsky.
I'll try to get a new version up with these changes in the next few days.
natebarney wrote: Thu May 23, 2024 1:14 am regarding the "Q" issue, would you find it more natural for it to return to the title screen or quit the game outright when pressed during gameplay? I'm leaning toward the former, but I'm curious what others think.
I enjoyed the game a couple of times via the online emulator. I'm sure if I had a controller on real HW I would have played it more.
Anyway I'd vote for "Q" exiting the game completely, no matter if in play or at the title screen. Having to exit game play then hit another key to exit the program would tempt people just to cycle the power, since that's a one step solution. If one is playing, why would one abandon their current game only to restart again back at level 1?
I'd even suggest changing "Q" to "X" and the description being "Exit the Program."
If there were options to change the level of difficulty, colour of the borders (some VIC 20 games had that silly option) or other configuration items then Q to exit the game play allows a player to change them then go play with modified settings.
natebarney
Edmond D wrote: Thu May 23, 2024 4:11 pmAnyway I'd vote for "Q" exiting the game completely, no matter if in play or at the title screen. Having to exit game play then hit another key to exit the program would tempt people just to cycle the power, since that's a one step solution. If one is playing, why would one abandon their current game only to restart again back at level 1?
That makes sense to me, thanks.
Edmond D wrote: Thu May 23, 2024 4:11 pmI'd even suggest changing "Q" to "X" and the description being "Exit the Program."
I see this point, but "X" is already used as part of the keyboard joystick, so I think it's probably better to keep it as "Q".
Edmond D wrote: Thu May 23, 2024 4:11 pmIf there were options to change the level of difficulty, colour of the borders (some VIC 20 games had that silly option) or other configuration items then Q to exit the game play allows a player to change them then go play with modified settings.
Yeah, this makes sense too, but I don't plan to add any options like that, so exiting the program entirely seems like the thing to do. Happy to consider pull requests though!
natebarney wrote: Fri May 24, 2024 12:39 am
Thanks - I was using the cursor keys and return to fire, forgot about the other keys that are used by the keyboard joystick. Pardon me, when I grew up computer joysticks only had one button, and when it got worn out it was time to ask the parents to buy a new one :D
natebarney
I've updated the game to incorporate the suggestions from this thread. The first post has been updated to reflect this.
natebarney
I've uploaded a new version which adds a PCM music track. The first post of this topic has been updated with new links.
I've been working off-and-on on a 3D voxel-art version of this game for modern PCs. As part of that project, I wrote a new music track, based on the original game's music. (The original music was pretty repetitive.) I recently learned of VERA's ability to play PCM audio, so I thought I'd add this track to the X16 game, as a way of learning how to use this capability.
The new music track was rendered to 16-bit stereo PCM at 44.1 kHz, but that was way too big. Surprisingly (at least to me), even after dropping it down to 8-bit mono at ~8 kHz, it still works pretty well.
I changed the tempo of the FM music from the previous version. It used to be at ~148 bpm, but I reduced it to 120 bpm to match the PCM music.
The M key still controls the music playback, but now it cycles through PCM, FM, and off, instead of just toggling FM on and off.
I'd be interested in any feedback (good or bad) about the new music. I wondered if it was too "hi-fi" sounding for this game, but a few people on discord encouraged me to go with my gut and publish this new version.
