ZSM-player without use of library
unartic
Post by unartic »
This example program plays any ZSM-file directly from disk.
However:
1. The ZSM-header has a value for 'tick rate'.
This example program will only play the zsm at the correct speed if the tick rate is 60 ($3C)
As it appears almost all ZSM-files have a tick rate of 60, so this will most likely not cause a problem
2. The EXTCMD-command is not implemented in this example.
This means the PCM channel is being ignored. So ZSM-files which use the PCM-channel will
have the PCM-sound missing
I'll upload another versions soon which will play PCM as well.
Source:
playzsm.asm
(8.37 KiB) Downloaded 191 times
Runable program:
playzsm.zip
(142.55 KiB) Downloaded 171 times
