AUDIO BOOK APP..VOLUME CONTROL
30 AUG 2024 - This thread is deprecated and closed.
I explored a lot of prototyping and ideas here. But what I have now is almost a total rewrite and has it's own thread here viewtopic.php?t=7929
12 Apr 2024
Uploaded newest update to my Google Drive. This is getting much closer to final look and Feel. Dynamic Menus and loading new books not yet enabled, I do have a few of the building blocks in place. This is about a 550mb download and about 1.8gb unzipped.
Here is the Link:
https://drive.google.com/file/d/1TijX20 ... sp=sharing
I also uploaded this update to Raven's BBS
Changed unzipped size to 1.8 gb's. That previous 3gb figure was MY Books directory that also has two of the zips in it ;) :?
The bug was at the end of the book When playing the very last Audio files. I've got it fixed.
ADDENDUM: You should not download this if installing the ALICE Update from the BBS. The Error fixes are rolled in on that. This is still under development so It's not going to be smooth... This is ALPHA or at best Very Early BETA software.
Posting here the first iteration of Volume Control
Code state is ALPHA.
2 full Audio Books are included, Bram Stoker's DRACULA & Mary Shelley's FRANKENSTEIN, also included is the DARWIN Chapter I previously uploaded in DEMOSCENE. They are selectable via Menu.
Most of the core code is done. (The Frankenstein Book doesn't play the PREFACE. Thats on the FIX list)
MENU is just a Hard coded Place Holder to select the 3 books I have done. This is the part that needs most refinement. The finished app will have a dynamic Menu.
Book Controls are not on screen.
BOOK CONTROLS
F1 - Toggles Graphics/Text Display
SPACEBAR - Pauses / UnPauses
ESC - Exits book with Y/N confirmation.
Both Exit and Pause will wait for the Current Audio Buffer to finish playing.
(Audio Buffers are approx. 6 seconds long)
Auto book marking and resume is enabled. (This will be able to be toggled when the code is more refined).
Currently if you want to restart a book you have to let it play to end or go into it's directory and delete BOOK.MARK
I'm still waiting for permission to upload to the Forum. But Jimmy Dansbo has provided a CX16 share folder on the cloud.
VCONTROL_ALPHA1 is available at https://cloud.dansbo.dk/index.php/s/FPT ... ALPHA1.zip
Its also uploaded on Raven's BBS viewtopic.php?t=7321
AUDIO BOOK APP..VOLUME CONTROL BUG FIX
BUMP FOR BUG FIX.
Re: AUDIO BOOK APP..VOLUME CONTROL BUG FIX
ahenry3068 wrote: Sat Mar 30, 2024 12:31 am BUMP FOR BUG FIX.
Are you asking for someone to hit you to get a bug fixed? :D
Edmond D wrote: Sat Mar 30, 2024 2:01 am
POSSIBLY :?
ADDED ALICE IN WONDERLAND
Added Alice In Wonderland to my Audio Book app.
The files are to Large to Upload here. I have uploaded them to Commander X16 Audio books on Raven's BBS.
(find a link to information on the BBS in the top post here)
If you've already downloaded VCONTROL Main archive you only have to download the ALICE Update. Otherwise you must download both, VCONTROL should be unzipped first then the ALICE Update unzipped in the VCONTROL directory
AUDIO BOOK APP. MENU PROTOTYPE.
NO Code for right now. Hopefully the Next Code Release will be something closer to what it I intend for the final in appearance. I still have a lot of work to do for Building the Menu's Dynamically but right now I'm working on Look and Feel.
I plan on this being a full fledged Audio Book Manager, Probably something that will live on it's own Large SD-Card. Part of the Package will be a Audio Book Import/Authoring program that will run in Windows or Linux (and Hopefully Macintosh, I'll need help cross compiling for that) and allow the End User to bring in their own Audio Books.
This is a REQUEST for Comment !.
PROTOTYPE OF LOOK AND FEEL I'M HEADING TOWARDS
ahenry3068 wrote: Sat Mar 30, 2024 1:12 pm
POSSIBLY :?
I believe I read in Code Complete (MS Press) that fixing a bug is more likely to introduce a bug than repair it. But at 900 pages I can't find the actual citation of the study done where this fact came from.
That being said, if a programmer could only read one book, that would be it.
AUDIO BOOKS: NEW UPDATE
POSTED LATEST UPDATE ON FIRST POST
Neat stuff - can the audio start partially offset from the start?
What I mean is - can "bookmarks" be possible? so you can pause or resume from a point, like if you switch books.
voidstar wrote: Wed Apr 24, 2024 7:20 am Neat stuff - can the audio start partially offset from the start?
If you've done the Big download https://drive.google.com/file/d/1TijX20 ... drive_link
I've already implemented "BookMarks" :) .
As a matter of fact I have it on by default. I have to add the option to restart the book to the menu. :)
