this prog8 can no longer be started.
funkheld
Post by funkheld »
Hi good afternoon.
Which Java version do you need to use?
I now have Win10
Thanks.
greeting
Re: this prog8 can no longer be started.
Java 11 or newer.
(this has been the case for a very long time... so something must have changed on your machine)
funkheld
Post by funkheld »
greeting
This would be better suited for the Programming or X16 Software Support forums. You'll get more feedback there.
funkheld
Post by funkheld »
hello thanks for info.
greeting.
