How to use AUTOBOOT.X16 and BOOT command
The X16 DOS has a command "BOOT" that ( per my understanding ) essentially does this:
LOAD "AUTOBOOT.X16"
(RUN is not necessary in the file because the BOOT command itself is going to do that)
So if your software title includes a ton of other support files, sometimes it is hard for end users to find the proper PRG file to launch your program. Or if you just don't want to type LOAD"xyz.prg" over and over while testing, you can prepare an AUTOBOOT.X16 (but it must be in the BASIC tokenized form, so you have to create it "on system" or in the emulator).
You could do other BASIC statements, like a menu to choose different versions of your runtime, or pre-set the SCREEN mode in a more appropriate resolution, etc.
Then just type BOOT to "run" your AUTOBOOT.X16
Re: How to use AUTOBOOT.X16 and BOOT command
Also, if there is an AUTOBOOT.X16 in the root folder of the SD card, the system will "BOOT" that automatically on startup.
