Melodius v0.1-pre1
MooingLemur
Melodius v0.1-pre1
Post by MooingLemur »
Melodius is a ZSM and MIDI jukebox for the Commander X16. It uses the built-in patch set from the in-rom audio bank as well as its API in order to play MIDIs on the YM2151. ZSMs are played via a new playback library called ZSMKit, which supports ZSM extensions for VERA PCM audio.
Notes are visualized as they are played.
Screenshot from 2023-07-24 07-42-30.png (51.64 KiB) Viewed 6384 times
A very recent ROM, newer than R43 is required in order to play back ZSMs. R43 will not play things back correctly.
To download a new enough emulator/rom, if you have a GitHub account, you can visit
https://github.com/X16Community/x16-emu ... 5607433748 and download a build for your OS.
Without a GitHub account, you can instead download from https://nightly.link/X16Community/x16-e ... 5607433748
Melodius v0.1-pre1: https://github.com/mooinglemur/melodius ... /v0.1-pre1 or download link below
This is a very early release, and it is fairly barebones, but it is capable of playing most ZSMs and most MIDI files.
Melodius-v0.1-pre1.zip
(3.47 MiB) Downloaded 287 times
