computer monitor?
computer monitor?
So i know this is going to have composite and vga inputs the problem is i have nothing that can display either of these formats. would there be the possibility of adding a monitor to this? or maybe someone can post where they have found either a composite or vga tv/monitor. i did a quick search on alibaba and found this: https://www.alibaba.com/product-detail/haina-2020-wholesale-CKD-SKD-opeitonal_62278750236.html?spm=a2700.pc_countrysearch.main07.22.143e5b875J0e8M
The only issue i have is its a bit on the large size. i would like something between 8-12 inches, for those of you who are using retro pc's(general term) what kind of monitor are you using? Keeping with the focus of this project i do not want to get an old tv or monitor from the 80s. I have thought about doing that and i may but not for this project.
computer monitor?
I went to a thrift store and found a VGA 17" LCD monitor for $10 - you might be able to find 15" monitors the same way or on Craigslist; however, I also bought myself a 10 inch monitor with multiple inputs (including composite and VGA) on AliExpress.
computer monitor?
Well, obviously you meant not input, but output. And Commander X16 does not have composite output. Only VGA.
This is a nice little monitor, but it's not that great for a retro expirience like X16, bacuse it's a wide screen monitor, not 4:3. You would have an ugly stretched picture by deafult. But some wide screen monitors have aspect ration function. So if this one has it, you may switch aspect ratio to 4:3, thus monitor will add two black bars on the left and right of the picture, making visible area 4:3 with no picture stretching.
Another important point is X16 outputs resolution of 640x480. So if you use LCD monitor with resolution which is not a multiple of these values, you will get a blurry image, because pixels will not match. So it is best to find 640x480 monitor (if such even exists) or 1280x960 (which is also not easy to find). Other approach is to choose very high resolution monitor like 4K or heck 8K - its resolution would not be multiple of 640x480, but it would be so high, that blurry effect would be almost unnoticable.
That is why lots of retro tech users choose to use 4:3 CRT monitors. CRT is analog and does not have fixed pixels on screen, thus does not care much about resolution, so it will display 640x480 nice and crisp. Besides, X16 case is a horizontal desktop type, and can host a CRT monitor on top of it, thus saving valuable space.
- SlithyMatt
computer monitor?
According to the FAQ, and the pictures we've seen so far, the VERA will have NTSC Composite and S-Video output.
Another thing to consider: most North American TVs that have component input also support composite video, usually with the Y (luma signal) component jack (usually green instead of yellow like most full-time composite video jacks). So, check your TV again.
Also, there are converters for VGA to HDMI or DisplayPort, but they are usually no cheaper than a thrift store monitor, which almost always have VGA inputs still.
So, you have no shortage of options, especially in the US.
- StephenHorn
- Contact:
computer monitor?
Unfortunately, the only thing I wish could be revisited is the 640x480 resolution, just because it's proving hard to find new monitors that will natively support that resolution. Folks support 5:4 multiples close to that, and 16:9 multiples close to that, but when it comes to 4:3, the closest you tend to see is 800x600 or 1600x1200. I don't understand why monitors worked out that way, but... well, they did. A pity.
That's hindsight for you, though.
computer monitor?
Truly my bad. It will. Sorry for confusion and thanx for correction.
computer monitor?
knew i wasn't crazy for thinking it had composite. the preliminary search i did yesterday didn't turn up much but ill keep looking. i wonder if any company especially Chinese still make CRT monitors? ill do some searching and if i find anything ill post it here. i still think the easiest thing would be to include a monitor as an option it doesn't have to be very big but something.
I did buy a 7 inch monitor from amazon for my rpi and now that im thinking about it i think it had multiple outputs on it.
computer monitor?
https://www.amazon.com/gp/product/B012ZRYDYY/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
it has vga so im set. its a bit on the small side but it would work in a pinch if i cant find something else. Could this monitor be included as a option with the x16? as i said it doesn't have to be big just something so people can get started on day one and not have to worry about a monitor.
- SlithyMatt
computer monitor?
I don't see any profit in doing that anymore, even from China. Thrift stores don't even take CRT computer monitors anymore (some still take CRT TVs, though).
I see listings of "new" CRTs on Alibaba, but I seriously doubt they are actually new, or even new old stock.
computer monitor?
Oh, sure. The 17" LCD monitor I got is 1280x1024, which is hardly perfect but good enough for me. The smaller monitor is also good enough for *me* as I like the smaller size - I'm fine with black sidebars, not as good image quality and I've used an SX-64 and Apple //c with the 9" monitor back in the day. I have no interest going with a CRT, though I get why many would like to use one.
