Some cc65 compiler questions
Re: Some cc65 compiler questions
ahenry3068 wrote: Thu Nov 16, 2023 12:17 pm Prog8 [...] It's very much a moving target
This is true in a sense, but I'm trying to keep it moving very little nowadays to avoid breaking existing code.
Johan Kårlin
Post by Johan Kårlin »
In the context, I want to say that I think Prog8 is an extraordinary achievement. I am very impressed and think it is a fantastic contribution to the community even if I am right now focusing on C and cc65.
I would like to return to one of my original questions. It seems that you can change the BASIC stub. As I have mentioned before, I found this done in the demo for ZSMKit. In the config, segments are defined like this:
SEGMENTS {
    ZEROPAGE:   load = ZP,       type = zp;
    EXTZP:      load = ZP2,      type = zp, optional = yes;
    GOLDEN:     load = GOLDEN,   type = bss, optional = yes;
    LOADADDR:   load = LOADADDR, type = ro;
    BASICSTUB:  load = MAIN,     type = ro;
    STARTUP:    load = MAIN,     type = ro;
    CODE:       load = MAIN,     type = to;
And in the code:
.segment "BASICSTUB"
.word entry-2
.byte $00,$00,$9e
.byte "2061"
.byte $00,$00,$00
.proc entry
	jmp main
.endproc
How do I write the same code in C?
Microdriver
Post by Microdriver »
Johan Kårlin wrote: Fri Nov 17, 2023 8:13 amI found this done in the demo for ZSMKit.
I guess, first thing would be to run the demo to see what it does (before changing things).
I can compile it, and load "DEMO.PRG" into the emulator, but after "RUN", nothing happens. What is supposed to be done?
Johan Kårlin
The demo loads some ZSM songs and plays them. But, actually, what the program does is not relevant in this particular case. I am just interested in how the one row in BASIC is generated. I can see exactly how it is done in assembly language and I think I understand how it works, but I don't know how to translate it to C.
Microdriver
Johan Kårlin wrote: Fri Nov 17, 2023 2:05 pmThe demo loads some ZSM songs and plays them. But, actually, what the program does is not relevant in this particular case. I am just interested in how the one row in BASIC is generated. I can see exactly how it is done in assembly language and I think I understand how it works, but I don't know how to translate it to C.
If you understand the assembly, couldn't you just use it to glue it to your C-program (as a startup-sequence)?
So when you type "RUN", the demo does something like playing songs on your system (I know, that's not the main-topic, but if the program is supposed to be the base for tinkering, it should at least work first, I think) ?
Johan Kårlin
I guess that is the problem, I don’t know how to connect the solution to my C program even if I know assembler. But sure it can be a start to see that the demo works and see where I can take it from there.
