Emulator Keymap
Dani
Emulator Keymap
Post by Dani »
I wasn't able to find this anywhere so I apologize if this has been asked before.  I found how to view and edit the keymap in the emulator, however, I was curious if there was an image that somebody had put together showing the X16 default keymaps on top of a modern keyboard that can just be kept open as a separate window to reference while working in the emulator?  I was thinking something similar to the image I'll attach of the VICE C64 keymap that somebody had made up.  I feel like this would make it much easier for newbies like me to get used to where all of the special characters are located as well as to be able to use all of the functions easily until I'm able to purchase the expensive keyboard.  I appreciate all of you in advance though!
Emulator Keymap
1 hour ago, Dani said:
Emulator Keymap
I just look at the official keyboard, which has PC and PETSCII characters on it.
https://www.wasdkeyboards.com/commander16-by-the-8-bit-guy.html
Dani
Emulator Keymap
Post by Dani »
I'm actually an idiot.  I never thought to consider that it would be mapped to the same layout.  I'm sorry for wasting everybody's time then lmao.
Perifractic
Emulator Keymap
Post by Perifractic »
No problem. We tried to make it easy that way so I’m glad it helped. [emoji4]
Perifractic, X16 Visual Designer
http://youtube.com/perifractic
