CUSTOMIZABLE SD Loader "PRGLOADV2"
Desert-Fox
Re: CUSTOMIZABLE SD Loader "PRGLOADV2"
Post by Desert-Fox »
Whew! Man I thought I was going crazy. BTW, yep, ROMTERM works fine when I dropped (1.27) in the directory myself. Is your program written in BASIC? I don't know if you would be willing but if you could the program listing in here to look at. You know more eyes on it. I would love to use your program.
Thanks - ROY
schristis
Post by schristis »
OK I definable found a difference on how the emulator "SEE'S" Data in data files??? if thats worth anything, I will report it tommorrow.
I'm a bit tired, So I believe the V2.3 should work with all the programs now
Best regards
Shaun
schristis
Post by schristis »
So I got a headache for a program working in the emulator & not on real hardware..
For what it's worth, I know it's not a perfect world.... just if any1 else runs into the same issue....
Files that use the OPEN# & CLOSE# statements can be seen differently...
The Emulator ignores spaces & real hardware doesn't... (Well thats what I'm seeing)
I've used the OPEN# to get information from this file to load programs.
Because there's a space behind the cursor.
It gives a "FILE NOT FOUND" on real hardware...
But works on the Emulator...
That's all it was.... I don't know if its worth doing anything about.... but Iv'e posted it.....
It might save someone-else some time.
But there's definitely a difference on real-hardware & the emulator !
I also put this in BUG Reports if thats ok lol....
Best Regards
Shaun
