So this video is 128 colors @ 15 fps
what do you think?
testing options for better video...
test online here:
Another Video Test
Another Video Test
video.zip
- (18.74 MiB) Downloaded 408 times
Re: Another Video Test
Have you seen the work me & Desertfish have been doing using Sprites as the frame ?badmai wrote: ↑Sun Dec 15, 2024 6:56 am So this video is 128 colors @ 15 fps
what do you think?
test online here:
I would be pleased to correspond with you on different approach's since I'm working on the same issue. Are you on the DISCORD ?badmai wrote: ↑Sun Dec 15, 2024 6:56 am So this video is 128 colors @ 15 fps
what do you think?
test online here:
I'm "DevMonkey" on discord, and have been following your progress.
I've done alot of tests using tiles/bitmap/sprites for video it always comes down to bandwidth from sd-card.
also I forgot to note, you can press SPACE to pause and ESC to exit
I've come to the conclusion that SPRITES are the best frame vehicle unless the Video is either 320 or 640 in width and can be blasted to VERA without scanline math. The Sprites allow that if set up contiguously in memory. TILE mode may have some application but it seems to me that would be highly custom and I for one would have a hard time figuring out a generic conversion routine.
Using Try It Now, the resolution was horrible, but the audio and flow worked great.
- clint.png (244.47 KiB) Viewed 14386 times
Testing my "updated" video code for the video I made for the release SD card..(was it included?)
CX16.zip
- (17.92 MiB) Downloaded 416 times
I've done a number of these over the years. The main bottleneck is getting data from the SD card to VERA. I've managed 20fps for a distorted image (2.35 to 1 converted to 160x32 pixels, then using VSCALE to stretch the vertical back to proper proportions). I've got some ideas for converting video to double PETSCII, perhaps with a special character set.
