Updates to BASIC EXEC
Is it possible/practical to have EXEC updated/extended to support true self-modifying BASIC code?
Tony and I have kicked this idea around. I'm thinking more in terms of the running BASIC code itself is generating the new plain-text line of code (with line numbers), and somehow using EXEC to get the new line (or modified existing line) tokenized "on the fly."
As a couple use cases:
imagine I have a DEF FN, but I want to dynamically alter what the FN does (like maybe change SIN to COS, but doing so based on some other state change and not have to do an IF check). What if the running program itself could generate a whole new line of code, and get that line updated - as an interpreted language, it seems this should be possible (but yes, require some extreme mastery of the existing ROM BASIC)
I think the real constraint is that the V2 BASIC needs to have bi-directional pointers for the tokenized line. The old 1975 IBM 5100, its ROM BASIC worked like that, each line of BASIC was prefixed with "next"/"prev" pointers, so they didn't necessarily have to be linear or co-located. So if you typed like 10, 20, 30, then added a line 15 - it wasn't stored in memory in the line number order, but in the order the user typed it (and the next-pointer associated with line 10 would jump to whatever line 15 was). I think they used the PREV pointer so you could press up arrow and at the top of the screen, it could find the prior line and display it (so you could scroll your code both up and down off the edges of the screen).
As another example, suppose I draw a random box, or decide the size of a box based on other criteria. Traditionally you'd have code like IF X < LEFT.SIDE.OF.BOX THEN TRIGGER.SOMETHING... But with self-modifying code, you could update this line in-place (so you didn't need a variable corresponding to LEFT.SIDE.OF.BOX - the line would be hard-coded to whatever the current numeric value was). I'm not sure if there is really any meaningful performance improvement (in terms of making a game or some content that wouldn't otherwise be possible without this feature) - but it's just a general gist of what this capability could be used for.
Anyhow, Tony and I kicked around some ideas - right now, the BASIC program could load its own plain-text form entirely (with the modified line), then EXEC that, then END itself - but then be bloated with checks to help resume where it had left off. I'm not sure if the idea of "self modifying BASIC" would have other more interesting uses - but I'm not aware of any 8-bit or boot to BASIC system that did have a feature like this.
Without a PREV flag in the format of tokenized lines, maybe it's just not practically possible to do. But just tossing the idea out there for consideration. I suppose another negative is, I'm not sure if BASLOAD could handle this feature. I suppose if in the self-generated lines, if you set them to be high line numbers (like 20000), you could produce some whole routines "on the fly." But modifying existing lines might not be practical.
Re: Updates to BASIC EXEC
I feel like this is sufficiently complicated, and sufficiently different from the way CBM BASIC 2.0 works, as to warrant being its own project.
Yeah, I'm hoping a more experienced CBM BASIC ROM expert might think of an easier way that might make this possible.
The "ultimate" use case I had in mind is: imagine running a BBS done in BASIC (or some kind of on-system "server"), and then remotely being able to inject or upload a line of code. It doesn't have to be a traditional message-board or file up/download thing, maybe a BBS that just plays command ZSMs (or a "private BBS" to control a telescope remotely). But while the BBS host is running, suppose it has a mode where you could transmit a plain-text string that gets parsed into tokens and on-the-fly alters the criteria of what audio is played.
But maybe the "ask" is more along the lines of some improved CHAIN support, to more seamlessly swap to another BASIC program without losing all the variable state (and without manually storing what you need to other BANKs, etc). i.e. the motivation isn't really just improving performance of BASIC. But just exploring a "what-if-we-could-that" in taking more advantage of the parsed nature of BASIC.
Ok, reading on it more - there's no real E-Z solution on this. I'm reminded that any modification to the program is going to right away stomp on the value of variables. That's just the memory map arrangement chosen by CBM V2 BASIC, that parsed variables get dangled off the end of the tokenized BASIC code space.
Hence discussions elsewhere, where once upon a time you could edit an existing BASIC line as long as the modified length was equal or less than the prior one. One could go out of there way (with REM statements maybe?) to ensure each BASIC line is max-length (not very practical).
So there is no way around it - you have to store down the values of variables you care about, to persist them from one runtime to the next.
Now, elsewhere we started talking about maybe using one of the System ROM banks to have some utility APIs (like a subroutine to provide a standard file-open selector). Another utility could be a standard way to export current BASIC variables to some kind of file or cache or BANK (with a BSAVE perhaps?)
So - is there a way to invoke EXEC and *not* have it stream the content to the screen? (maybe not, and still have it recongized as BASIC input to the KERNAL).
mobluse
Post by mobluse »
Another way to do the same thing would be to have MERGE or CHAIN commands in BASIC, like in MBASIC, GW-BASIC, Sinclair BASIC (1982), and ABC 80 BASIC (1978): Then you could, from the program, write a text file containing a BASIC program and then MERGE or CHAIN that. CHAIN in ABC80 was simpler than in GW-BASIC and required you to store variables using POKE and restore them using PEEK.
mobluse wrote: Sun Dec 15, 2024 8:50 pm Another way to do the same thing would be to have MERGE or CHAIN commands in BASIC, like in MBASIC, GW-BASIC, Sinclair BASIC (1982), and ABC 80 BASIC (1978): Then you could, from the program, write a text file containing a BASIC program and then MERGE or CHAIN that. CHAIN in ABC80 was simpler than in GW-BASIC and required you to store variables using POKE and restore them using PEEK.
In the BASIC on the X16 LOAD "MYPROG.PRG" from a running program, loads the new file into memory and starts it. It does completely replace the old BASIC program in memory (Including all variables) but that only effects the 48k of BASIC low Ram. There's plenty of places on the X16 that the calling program can stash information to be used by the called program.
Information can be stashed in any Free High ram Bank. In Golden Ram ($0400-$07FF) and in Ram Bank 0 at $BF00-$BFFF (only).
Information POKED here by the program doing the loading can be PEEKED by the loaded program.
HANGMAN & Volume Control both make extensive use of this technique.
mobluse
Post by mobluse »
As it is now you cannot LOAD a BAS file programmatically, I believe, and it is difficult to write a PRG file from BASIC with e.g. new functions (DEF FN) or subroutines. The purpose is to be able to write self modifying programs. A MERGE command that works from the running program for merging BASIC source and that preserves variables would be useful.
mobluse wrote: Sun Dec 15, 2024 11:59 pm As it is now you cannot LOAD a BAS file programmatically, I believe, and it is difficult to write a PRG file from BASIC with e.g. new functions (DEF FN) or subroutines. The purpose is to be able to write self modifying programs. A MERGE command that works from the running program for merging BASIC source and that preserves variables would be useful.
You very well could LOAD a BAS file in BASLOAD file with EXEC & using the BASLOAD command. I get your point but while I'm not one of the system developers I'm pretty sure what your asking would be a bit more than the current "wedge" commands that are being added and involve a good bit of jiggering BASIC's internals... I do a bit of self modify code from BASIC right now but I use one of two approachs. I do some poking of parameters in Machine Language sub routines based on what file I'm opening with them. You can also have multiple different PRG files to load based on some program condition. I don't really see any thing that a merge command would accomplish that can't already be done a different way. EXEC & LOAD together give you much of what you want.
