Living Type - A Chinese Word Processor
Inkbox
Post by Inkbox »
Living Type for the Commander X16
A Chinese Word Processor for the Commander X16 that supports 10,000 Chinese characters.
The program itself is called "HUOZI.PRG" and the resources should be kept in a folder called "huozi" on the SD card or file system.
Huozi is the romanization of 活字, the name given by Bisheng to his 11th century invention of moveable type.
IMPORTANT: The huozi folder and should be kept in the same folder where the Commander X16 emulator is located in order to run properly.
LOADING:
From the home screen of the Commander X16 load the program with
LOAD "HUOZI/HUOZI.PRG"
Followed by
RUN
Once the program is loaded press any key to get past the title screen.
CONTROLS:
To toggle Chinese input press: SHIFT + SPACE
To toggle Command Mode press: CTRL + C
There are 4 commands the program can preform:
1. save
save [filename]
Which saves a binary text file to the huozi folder and [filename] represents your given name to the file
2. load
load [filename]
Which loads a binary text file from the huozi folder and [filename] represents the given name of the file
3. new
new
Which creates a new document for the user (erasing all current data held in memory)
4. color
color [0-9]
Which sets the text color to one of the ten selected colors
Demo
In Command Mode try out
load data
To see a text file containing 4800 Chinese Characters
load david
To see some PETSCII art
Fixed a bug that didn't clear the whole file data section of memory when loading in multiple files in a row
huozi.zip
(308.3 KiB) Downloaded 445 times
Napoleon333
Re: Living Type - A Chinese Word Processor
Post by Napoleon333 »
This is confirmed to work according to Inkbox's video https://www.youtube.com/watch?v=bFIk8WV-RYQ
So it would be nice to move this post into the "Downloads < Productivity Apps" folder instead of "Downloads < Archive".
